Discuss Lwden TPN dist doards. . . . . . . . in the UK Electrical Forum area at ElectriciansForums.net
What exactly is the quote for?Lewden TPN Dist boards. . . . has any one used these boards before. I have just got a quote which seems ridiculously cheap, so I am questioning myself regarding the quality and availability of mcbs, rcbo's etc. . . comments please
strange question. . . .. to replace a undersized existing TPN crabtree Polestar, in a commercial propertyWhat exactly is the quote for?
Not at all your post mentioned the DB and asked for comments, so I merely asked what was included in the quote.strange question. . . .. to replace a undersized existing TPN crabtree Polestar, in a commercial property
my post asks if anyone has anyone used these and the quality of board.Not at all your post mentioned the DB and asked for comments, so I merely asked what was included in the quote.
quote is per board, per main switch, per mcb b type, per rcbo b type.Check you have been quoted for the number of mcb's etc you have asked for and that they have not given you a price for an individual breaker for you to work out the price for the quantity required. Have been caught out myself in the past with this.
OK thanksquote is per board, per main switch, per mcb b type, per rcbo b type.
Just me being a nosey Gotmy post asks if anyone has anyone used these and the quality of board.
ah!! some feedback... . .. cheers dood. Placing order as we speak. I'll give it a go and if I don't like it I wont use it again.nowt wrong with lewden gear. if price is right get it in there.
yep I've there commando plug and sosckets a few time and fine.As an endorsement for the brand, we have many Lewden IEC60309 (ceeform) connectors and have always found them to be a very good brand, up there with Mennekes.
If I had the money on the job I'd probably go with Hager or Schneider. . . .. I'll let you know how it goes.Make sure they've quoted for 10KA MCB's as 6KA won't fit...same with RCBO's. They aren't bad boards...if the budget is tight on a job I usually put these lewden TPN boards in.
Reply to Lwden TPN dist doards. . . . . . . . in the UK Electrical Forum area at ElectriciansForums.net
