Macerator spur from lighting circuit??? | Page 2 | on ElectriciansForums
Discuss Macerator spur from lighting circuit??? in the UK Electrical Forum area at ElectriciansForums.net
Gringoking88
London
Hi all,
I have been asked to install a spur for a Macerator in an existing bathroom. At present the bathroom has an electric shower and that's it, there are no sockets near or in the bathroom.
I was thinking to drop a feed from an RCD protected FCU from the lighting circuit in the loft to feed a switched flex outlet, to in turn feed the macerator. My question is, is this the most suitable method and also what would be the IP requirements for the connection unit in the bathroom, do I need make sure its outside of zone 2 etc e.g. 60cm away from the bath / taps etc?
Many thanks in advance,
Martin
I would make sure that all circuits in the location are protected via 30mA rcd excluding selv lighting , or at the very least there is supplementary bonding in place between circuits and any exposed pipework (metallic) that isn’t isolated from any extraneous pipework.
Ian,
Is this you going above and beyond? The regs say only the work I complete has to be upto current regs and there is no need to "upgrade" existing circuitry?
Yes but you are installing wiring in a special location and special locations such as bathrooms come with specific regulations.
That is my understanding of the regulations regarding bathrooms.
Yep, 100% it is on a 15amp fuse, earthing of lighting circuit is satisfactory, but am unsure why I need to upgrade bonding???
You don’t necessarily need to upgrade any protective bonding conductors , just need to verify they exist if required and are satisfactory.
If extraneous conductive parts exist within the installation and do not have any protective bonding conductors Connected to the MET then your work can not proceed.
Only time I see 15amp lighting circuits are older commercial properties/factory units where the lights have been wired in pyro 1.5mm or 2.5mm for banks of fluorescent lighting.
Even then they are bs 3871 devices so 16amp.
Thinking vorti is being practical here. Even if dropping circuit into bathroom, feed it out to hall/bedroom and keep CU out of the bathroom, leaving you options for cabling under floor/bath/whatever?
I say this not as an expert, but I know my spa bath has a power supply from the loft, via an RCD in the bedroom cupboard, to a switched outlet and then through the bedroom wall, under the units to the bath motor, thus no connections in the bathroom at all, apart from the final ones at the motor...and the same for the electric shower. I bow my head to those who really know about these things, naturally...
Reply to Macerator spur from lighting circuit??? in the UK Electrical Forum area at ElectriciansForums.net
SOLVED Thanks for all the help. It was nothing to do with the smoke detector. In this new hole (where there will be a light fitting) three white...
