Magnetic door sensor to turn on led light problem | Page 2 | on ElectriciansForums
Discuss Magnetic door sensor to turn on led light problem in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Drawn the circuit up for you, note that a/b/c are all one 14 pin 4001 (yes changed my mind) The circuit draws only 1 micro Amp in standby, and thus through the contacts. It is the basis of most security alarms. When the mag reed is closed all is ok, open the switch and the led and relay are activated, close the switch and the are de activated. simples, hope this helps
View attachment CCTV Alarm input.pdf
Reply to Magnetic door sensor to turn on led light problem in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
It does seem to me that there's a capacitively coupled voltage to each set of downlights (on the light side of the switch), and when you put the...
Is the cabin light a lamp or an led ?
