MAin Beam lights 2008 Ford Fiesta | on ElectriciansForums
Discuss MAin Beam lights 2008 Ford Fiesta in the Auto Electrician Forum area at ElectriciansForums.net
Plymouuth
2008 Ford Fiesta headlights come on as normal but when I go to main beam nothing happens the lights go out, ie main beam lights do not light up at all? all other lights are ok
It very well could be, I thought that after I posted, went outside t the car, can I find engine compatrment fuse box can I heckus like, looked at manual owners still cant see it, mind it is dark
ford usually putfuse box under passenger side dash, below glove box. the engine copmartment fuses are next to battery.
If you do a google search there are hundreds of images and instructions about where to find the fuse boxes and what the layouts are. This will save you the hassle of searching through each fuse.
Reply to MAin Beam lights 2008 Ford Fiesta in the Auto Electrician Forum area at ElectriciansForums.net
Ok, after trying two different flashers supposedly for Led bulbs, I got one that also has a ground wire, and it worked. I now have operating turn...
Back to the Men's Shed today to complete the installation of the 4 LED battens in the attic. These were a joy to fit, having screwed the units to...
Recommended Sponsor News
thanks for the clarification. ( also thanks to Dan. ).
More info on link below http://sbsc.uk.net/
9K
Happy Friday Everyone! Subscribe for more jokes direct to your mailbox or send us your own jokes to be in with a chance of featuring, by clicking...
6K
