J
jase31
Should the MET be the earth point in the CU, with a separate single cable (10mm) run to gas, and electric meter, or could the MET be 8 way earth block on the meter board with a 10mm cable run to consumer unit, and water stop tap.
Should the CU be connected by a 10mm, 16mm, 25mm earth cable on a small domestic supply.
