Main bonding & speedfit pvc pipes | Page 2 | on ElectriciansForums
Discuss Main bonding & speedfit pvc pipes in the UK Electrical Forum area at ElectriciansForums.net
L
LlandrilloSpark
Fella's
I was told today by a spark a lot more experienced than me that I need to bond the following, I'm inclined to agree but could do with some opinions.
Water comes in on 15mm copper where there is a 300mm length before it is then converted to PVC speedfit,this whole section is hidden in a cupboard, it does go back to copper eventually.
Is it worth bonding that small section?
the building is all in plastic speed fit is it not?
quote o/p,
"Water comes in on 15mm copper where there is a 300mm length BEFORE IT IS THEN CONVERTED TO PVC SPEEDFIT"
Fella's
Listen to the Spark that has a lot more experience than yourself, as well as the experienced guy's on here that are telling you exactly the same thing!! lol!!
Reply to Main bonding & speedfit pvc pipes in the UK Electrical Forum area at ElectriciansForums.net
The power company only brings in 3 wires which is 2 live and 1 neutral wire. It’s our responsibility to add the ground rod to bond the neutral...
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
