H
hughesy1982
Hi guys! im wiring a barn conversion and am not sure what to do about the main earth to the building.
The barn that is being converted has no mains source to the building. The power source into the plot comes into another barn alongside which is having no renovation done at the moment. i have run a 25mm swa from a henly block to a 80a switch fuse from the incoming mains into the consumer unit into the barn conversion.
My query is can i use the spare core in the swa and connect to the main earth terminal at the mains end into the main earth terminal inside the consumer unit?
