Discuss Main isolation by local REC in the UK Electrical Forum area at ElectriciansForums.net
A number of reasons:How come us electricians have to put in metal Db’s,they come along & put in a plastic isolater,for us to connect to.
why ?I'm starting a rewire next week and I've decided to not take any chances for the isolator so I'm fitting one of these:-
why ?
both !Why a metal enclosure or why am I fitting an isolator
in Sparkychick case pink &white .And it would remove grey and introduce black and white !
Does it comply with the required standard?I'm starting a rewire next week and I've decided to not take any chances for the isolator so I'm fitting one of these:-
EM220 - 2 Module Metal Enclosure IP20 rated 145 x 80 x 62mm with Lid for Circuit Protection - https://www.sparksdirect.co.uk/2-module-metal-enclosure-ip20-rated-145-x-80-x-62mm-with-lid-for-circuit-protection#.WoX0IDvLiUk
The intake and isolator are under the stairs, so definitely a good reason to err on the side of caution.
any isolator up front before the new c/u does not require a metal ,
but if you are happy ,then go for it ,
Reply to Main isolation by local REC in the UK Electrical Forum area at ElectriciansForums.net
