Discuss Main isolation by local REC in the UK Electrical Forum area at ElectriciansForums.net
That's the oneI think you meant non-combustible enclosure.
Thick moment what's REC??
Agree. If a manufacturer had obtained BS EN 61439-3 approval for their product then I guess they (at least) thought it was a similar assembly.Problem with this requirement, is the ambiguity.
What are “similar switchgear assemblies”?
My understanding is that it is intended to encompass TPN DBs when used in a domestic setting. Why they didn't just state "distribution boards" instead of "consumer units and similar switchgear assemblies" is a mystery though.Problem with this requirement, is the ambiguity.
Regional Electricity Company
Rec = regional electricity company, same as dno?
And Sparkychick sorry SCNever heard that before, so as @Pete999 said... everyday is a school day... thanks chaps
I typically flatten the tails with pliers, tighten them, wiggle, retighten and then periodically check them as I work on the board.
ESF investigation on termination of meter tails:
Tightness of Meter Tails - https://www.----------------------------/electrical-professionals/product-safety-unit/tightness-of-meter-tails/
Reply to Main isolation by local REC in the UK Electrical Forum area at ElectriciansForums.net
