main protective bonding.... supplementry bonding
i=p/u
was working today in house and plumber has pulled boiler and water tank out ripping all bonding off. the existing pipe work had supplementry bonding across pipes.
question.. can i leave the supplementry bonding off too new pipework if have main protective bonding to my oil and water and circuits are rcd protected
If the house is protected by an RCD and you have 10mm bonding to all incoming services, then it is unlikely you will need any additional bonding between various boiler pipes.
As already said tho, hard to say for certain without seeing it.
il take my camera tomorrow guitarist by then you can explain me how to upload to this forum.. they always seem to big.
I attempted to upload 4 * 4MB. The whole process went on for ages and then failed.
I would suggest that you change the settings in your camera to 640 *480 pixels. This then will allow you to upload your pictures easily
