Luminous
- Joined
- Nov 8, 2010
- Messages
- 44
- Reaction score
- 3
Just changing a CCU and the existing bonding to the services is in 6mm. I can get to the gas incoming very easily to change to 10mm but there is no way I can get to the water incoming service (middle terrace, stone floors, just decorated) without a load of trunking or up and over the house. Even if I did the service is now behind the kitchen units with just a small hole for the stop tap.
However, there is a radiator pipe below the CCU. Can I bond to that? Looked throughout the regs and can just find 'as near as practicable to point of entry'. This seems to be the nearest most practicable point but it's obviously from the 'wrong' side of the boiler.
Any advice?
Any advice?
