Mains fuse concealed in wall cavity | Page 2 | on ElectriciansForums
Discuss Mains fuse concealed in wall cavity in the UK Electrical Forum area at ElectriciansForums.net
Mickey81
West Yorkshire
Hi all.
I have a question i'm hoping some of you can advise on.
A long story short my main fuse has been hidden in the wall cavity(by the previous owners - which was not picked up on my survey before buying the house) and after pulling off the wall tiles recently to retile my kitchen I've stumbled across the access panel to this mains fuse(pictures attached).
After arranging a smart meter fitting with octopus energy the engineer came out today and won't touch it. I did think he wouldn't once he saw it.
The mains fuse is above my cooker and on the other side of the mains is the electric meter and cut off(pictures attached).
My question is.
Re-tile over it and put it back to how it has been for the last 10 years.
Report to Northern Power Grid. By reporting it I'm making them aware of this and a really am not willing or can afford to pay for this moving.
Or anyone had a similar experience could offer some advice I'd really appreciate it.
Thanks.
  • [ElectriciansForums.net] Mains fuse concealed in wall cavity
I had the same thing last week bizarrely, main cut out was behind a floor corner cupboard in the kitchen, back panel screwed in and behind that a stud wall plastered with the main fuse within….what really baffled me, I was called in as the owners had just bought the place and couldn’t find the main fuse, was they (previous owners) had had a smart meter fitted but there was no way the meter monkey had been near the main fuse….🤔😂
Tiling around and cutting out the access panel is looking the likely option at the moment.
I think the service head needs moving or you need to redesign the kitchen, the tar leaking from the service head could be down to a build up of heat in the void when using the cooker if you make an access panel that isn't completely sealed any steam or water vapour could build up in the void when cooking and cause a failure of the supply
Maybe you could get the cut-out replaced and upgraded to PME. If so, Then you could turn it around to face to the outside wall and move the outside cabinet to give access that way and provdie a heatproof sheild on the inside. Anyway off the top of my head that is all I can think of. Otherwise it is move the range over and provide access inside. Wow, what a headache!
P.S. perhaps they could even move it into the cabinet outside and the isolator to the inside.
Reply to Mains fuse concealed in wall cavity in the UK Electrical Forum area at ElectriciansForums.net
I would hazard a guess your electrician may be able to contact your DNO and have the switch swapped to a MFS very quickly..
I can't help wondering about earthing arrangements and how important aesthetics really are when attempting to make the best of a less than ideal...
nicebutdim
N
