Mains operated interconnected smoke alarm | Page 4 | on ElectriciansForums
Discuss Mains operated interconnected smoke alarm in the UK Electrical Forum area at ElectriciansForums.net
Neptune
United Kingdom
I fitted these into my own house a few years ago when everything was ripped open and hence, am familiar with the process.
However, on this occasion I need to fit these into a property that I let out and I don't have access to the ceiling void on ground floor.
I was thinking about using trunking and wanted to check on what type of trunking is neat and recommended for this purpose. Also, how will this merge into the existing light pendant (standard light pendant hanging from the ceiling).
Finally, I assume that I will need to trunk to the switch and not light if that's where the permanent live is. If this is the case, how will the trunking merge into the existing light switch?
Never had to use trunking before. Thanks in advance.
We install Aico alarms only
The mains bases have a bit that snaps out to allow YT2 mini trunking.
Also- BS5839 Pt6 has been updated to allow 10 year sealed radio linked detectors.
As others have said - ask the council officer for documentation requiring the mains only ones
The 10 year ones do work and last- the Aico ones even bounce the signal from one detector to others in a 'mesh' type of system. This way if the alarming unit is almost out of range of the furthest unit the ones on the way pass the alarm signal on (as well as the silence signal)
Hi Guys,
The LA is Bucks. I could have gone back and challenged their view on this. I appreciate your help with this.
In the interim, I was able to identify a route which has minimal trunking on display. All of upstairs is free of trunking as the power and interconnect cables are routed through the loft. The interconnect cable downstairs is run through a cupboard in the landing and I've also been able to minimise trunking that is visible on the ground floor.
I have complete trunking and cabling and now need to fix and wire in all the detectors. I have not connected the power supply yet.
Will share pics once complete. Thanks again.
Reply to Mains operated interconnected smoke alarm in the UK Electrical Forum area at ElectriciansForums.net
SOLVED Thanks for all the help. It was nothing to do with the smoke detector. In this new hole (where there will be a light fitting) three white...
