maintaince free junction box | Page 2 | on ElectriciansForums
Discuss maintaince free junction box in the Electrical Tools and Products area at ElectriciansForums.net
@diyterry give us a little more background of what your looking to acheive and we may be able to sujest other methods, possibly, just noticed your in Suffolk too, so if you do get in a tangle give me a pm
In the past someone has connected a lighting circuit to the ring main via a switched and fused surface mounted box, this is now obsolete, so I'd like to remove it to tidy the wall up.
This the same spurred light you wanted to fit back in September 2017.
Enlighten me Pete i'am here to learn.
What used to be classed as a "Ring Main" is classed as a Ring Final Circuit or RFC not to be confused with a Radial Final Circuit, can be confusing, but nothing brasses me of more than people using the cincorrect definitions of electrical things. A Ring Main still exists but is normaly designated for distribution circuits, such as a HV Ring Main, as an example. Check out Appendix 15 in BS 7671 if you have a copy that is.
That's great thank you, I've written that down.
Reply to maintaince free junction box in the Electrical Tools and Products area at ElectriciansForums.net
I don't really know if he is or not, but I would have thought an electrician would be able to calculate cable size or know about requirements for...
If you get a length of conduit, and seal both ends then the IP rating will instantly be IP68!! If you buy an IP66 rated Wiska box it will...
