maintenance of transformer
If your talking about a power distribution Transformer ie ...11000/415/240 volts, then without being funny, ....unless you know what your doing, you shouldn't be getting involved in testing such transformers. And as you don't know what tests to perform or what these tests are for, ...Even more reason why you should be leaving such equipment to those that DO know!!!
post the details otherwise we can’t help. But to be honest I’m dubious as to your competence to carry out the tests or if you would have the equipment required.
HI!everybody help me. How do you test a power transformer? and what is test for? thanks!
If your talking about a power distribution Transformer ie ...11000/415/240 volts........
Hell, I hope it's not a HV distribution transformer you're talking about.
Can you give more details or even better attach a photo. There's loads of different types of transformers and the testing procedures vary radically.
Could just be that the transformer is on his model railway and he don't want the fat controller hurt.
