Maintence Free JBs (MFJBs) | Page 3 | on ElectriciansForums
Discuss Maintence Free JBs (MFJBs) in the UK Electrical Forum area at ElectriciansForums.net
Pete999
Northampton
Just read an interesting article in Octobers "Professional Electrician and Installer" (PE&I). Probably going to get my --- ripped to shreds over this, "You should have known better Pete"
How ever many of you now use Wagos, I don't cus I'm retired, according to the article and I quote "" It's important to note that the connectors and the enclosure do NOT qualify on their own as Maintenance free accessories, This is because an Accessory is defined as the whole equipment and may comprise of two products-the connectors and the enclosure-both have to be certified for use together, and installed according to the manufacturers instructions"".
It made me think of how many Domestic Electricians put these Wagos in a, say for example a CU extension box and call it Maintenance free, or in an adaptable box under the floor? made me think, what do you lads still on the tools think, am I making something out of nothing? shall I just shut up and drink the red stuff,? or am I onto something?
I await the backlash of abuse but I don't give a damn
Eh? You'll have to explain that one to me! o_O
Hi Archy, The feedback I got from manuf. was that all 3 connectors needed to be fitted within the RH end containment area of the Wagobox (in my pic). That is possible with the 773-104 connectors but not physically possible with the combo I had used. My combo would work perfectly well, baggy pants and all, but it isn't the physical config that was used in the MF testing and subsequent approval.
And V - yes the connectors are not marked MF, just the j box. That was what started me on my little journey to understand this a bit better. I'm still not 100% clear why not, but I think they don't mark them MF because the connectors by themselves do not qualify as MF. But the empty Wagobox does. Somehow that reminds me of a Yes Minister episode...
The idea of the maintenance free box is that it has been tested as an assembly under the rather rigorous test conditions and does not fail. If you vary the design of the whole enclosure by making changes then it is possible it would no longer meet the MF requirements.
For the wago box the testing is with the design they have specified anything else has not been tested.
As Richard points out, a leading cause, if not THE leading cause of bad connections, is bad electricians. Surely they are the ones who should be tested under rather rigorous conditions, not the boxes?
I am certain those 222 connectors used to connect the baggy cpcs comply to BS5733.
Wagobox produced a "FAQ" about their boxes, see the handy resource section.
The funny thing is, for years I've been carrying around the maufacturers' instructions in my bits box that claims compliance with BS5733 in case I was ever pulled up about it - I never noticed that the wagoboxes had the MF logo printed on them until wilko's post #19. I guess I'm just not used to stuff being stamped on the inside of boxes!
As for Pete's original post: I use wagos in a wagobox installed as per manufacturer's instructions as a MF joint, if I have to.
How I'm going to make my millions: an MF joint that you can use in the event of cutting though a cable, without adding a short "joining" length and needing two joints. So something that's sufficiently long (3-5cm?) and thin that you could strip the ends off the two bits you've sliced, join them together, then wrap around an enclosure, not much bigger than the original cable, all properly MF.
Isn't it just hilarious that here we are, professional electricians worrying about whether a connector is in the end segment of an enclosure, when 90% of the population including DIYers, builder, plumbers, handymen etc. simply stick the wires in a chocky block and, if you're lucky, wrap a bit of insulation tape around it.
Then, to top it all, some smiling head of "the electrical industry" on a vast salary tells us how great everything is.
I believe the intent is that with tape over it you cannot accidentally push a metal rod onto a live piece of connector. Because this is just so likely.
Mainly a nuisance and I habitually put my probes through the tape to test for voltage, just causes problems and is a mess to take off, unless it is really old and just crumbles off.
I think we're starting to over think things that are second nature to any decent and competent sparks, in the end you can start to even doubt yourself.
I'm sure we've all come across hundreds of old screw terminal JBs in loft spaces and under floorboards, the vast majority if connected properly in the first place will still be perfectly ok with tight terminals etc.
As far as 'maintenance free' goes I'm happy to use the Ideal 'In sure' connectors in any suitable enclosure, often a small grey Schneider insulated enclosure. I'll secure the box with screws wherever possible and clip the cables and that will do fine for me, the only real advantage IMO is time saved especially in awkward areas, but I'll only use 32a rated connectors on RFCs just to give piece of mind.
Remember that the MF testing (at least from wago) means that the current rating of the connectors needs to be derated for MF use. So a 32A connector will be derated to 20A, which is still fine for a RFC.
Never understood why people wrap connectors in tape.
Probably adhering to the second half (if not the first!) of 134.1.1, prior to amendment 3...
[ElectriciansForums.net] Maintence Free JBs (MFJBs)
Reply to Maintence Free JBs (MFJBs) in the UK Electrical Forum area at ElectriciansForums.net
