With reference to a post you made just 5 days ago, I can only assume this is the same property:
"I would value peoples opinions the earthing arrangement I cam across yesterday. Water and Gas main protective bonding conductors were not installed at the consumer unit, but were coned to the main earthing terminal. The MET was connected to the distributors earth and one conductor ran from the MET to the consumer unit. The resistance from the consumer unit to the gas and water were fine at 0.01 Ohms. But shouldn't the conductors be wired into the consumer unit? They all need changing anyway as they were all 6mm."
http://www.electriciansforums.co.uk...trical-forum/102345-earthing-arrangement.html
So based on this, you knew they were on the small side before you started the work, so why have you carried on and not updated them?
