Hi,
I have a 10.5KW electric shower in my home with a 50Amp 1 gang double pole switch fitted outside for it.
I wanted to convert this switch into a smart one so I can turn it off remotely when I forget to switch off the shower in morning.
However, I have been unable to find any wifi/zigbee switch that can do this.
The only switch I found was zwave and its 40amp only so not sure if that would suit either. Z-Wave Plus Aeotec Heavy Duty Switch - https://www.vesternet.com/z-wave-aeon-labs-heavy-duty-switch
I would be really greatful for any ideas about this.
You could put a smart switch that activates a contact, in line with the isolator.
Still not quite sure why you require this.
Ahh the old should i shouldn't i turn it off, most think it should be left on at all times and only switched for maintenance as already mentioned.
I kind of also toe the same line as 'what is the point', maybe a smart app' to improve your memory would be better than relying more on technology to do your thinking, I don't see the consequences of forgetting to turn it off unless we lack info' here.
Our confusion aside and as mentioned earlier the best way is a contactor with push button operation and a retaining coil, the App would act like the off button and drop the contactor out, I'll ad that your going to be throwing £100 + at it in parts alone then fitting cost for something I struggle to realise the need for.
Edinburgh
Making an electric shower smart
RemoteSojourner,
Squid,
