Makita Wall Chaser | on ElectriciansForums
Discuss Makita Wall Chaser in the UK Electrical Forum area at ElectriciansForums.net
TJC1
Evening people!
Finally convinced my boss to invest in a wall chaser!!
Looking at getting at Makita VC2512L wet & dry extractor unit with a Makita SG1251J wall chaser.
Does anybody have this set up? Or recommend another setup?
Many Thanks
Got the same wall chaser and use another wet/dry extractor unit, does the job well! Even chased when house occupied and furnished!
The extractor unit I have, has a socket you plug the chaser into and when you turn on the chaser the vacuum starts and then stops soon after you turn off the chaser!
Dust Extractor Fox F50-800 Woodworking Machines Wet and Dry Vacuum
I run the makita wall chaser with a Bosch gas 35 m class vac. Must say its the nutts. Had to adapt the hose as they were not compatible but works great. Can also buy dust bags with a zip so that they can be reused.
Reply to Makita Wall Chaser in the UK Electrical Forum area at ElectriciansForums.net
Thanks for the replies, I appreciate it.
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
