Marcrist Core set with dust extract | on ElectriciansForums
Discuss Marcrist Core set with dust extract in the Electrical Tools and Products area at ElectriciansForums.net
Agree with above; burnt out one core drill with just one hole in wet garden brick work. If wet core drilling is available for hire, I'd go with that.
Not keen on the idea of wet core drilling, the jobs are domestic bathrooms, and I'd imagine the clean up operation after 1 core will be a nightmare. There is no issue doing the core dry, it's just it takes around an hour on average and it's the wet/damp dust that slows things down, if the kit in my opening post brought that down to 30 mins, then happy days.
The Marcrist dust extract system is pretty good.
A few issues:
If using a core bit with slots, you need to tape them up to stop the dust flying out. The tape wears off and needs renewing for each hole drilled.
Using a Henry works OK, but I suspect that the restriction in airflow causes the Henry to get too hot from lack of ventilation. Maybe need to allow some extra air to bleed in.
I start my cores by screwing a disc of wood to the wall, cut to the inside diameter of the core, as a guide. You don't need a pilot bit so can use extract from the start. Once you're a few millimeters in, you can remove the guide block.
One thing I found that helped with damp brickwork was to get the core started then SDS four holes 10-12mm at 12, 3, 6 and 9 oclock.
It helps to keep the damp clay like dust from building up and binding the bit.
this was with Eurbauer core bits from Sxcrewfix, never tried the expensive ones.
Reply to Marcrist Core set with dust extract in the Electrical Tools and Products area at ElectriciansForums.net
how often will you need to use it? Would renting one from a tool hire place be more cost effictive... and might give you an idea of good brands...
Sounds more positive.
