Guest viewing is limited
View the thread, titled "Master RCD switch cutting out - HELP!!!!" which is posted in DIY Electrical Advice on Electricians Forums.
Max, we have to draw a line at some point and I believe we are now starting to cross it. Pass this job onto your electrician friend or call a local electrician and tell them what you have told us. We have worked out the possible faults just by your posts, I'm sure they will as well.
ps tell the sparky bring a MFT and a Pz2 screwdriver with him, thats all he needs imho. This needs to be done by a professional and will not cost that much. Good luck with it Max.
Max what the members have told you on here is clear and concise. sometimes though it would be the equivelent to me trying to diagnose my engine management fault light on the car with a basic ohm meter. I am not into stripping my car down and sometime I have to take it to the garage. please treat the electrical problem you have at the moment in a similar way.
the best way forward is to get a professional in. if you like I could post a threat saying "electrician wanted" on here or you could go onto one of the schemes websites and search for a qualified electrician around your post code.
thanks guys for the replies and let us know what he says Max.
Thanks for all your information I respect you guys for trying to help and being sensible. I did speak with my friend last night and I have told him everything I have told you guys. I will pass on the information you have said to him to help him find the problem quicker just need to try and get him down here now :-) Thanks once again.
Reply to the thread, titled "Master RCD switch cutting out - HELP!!!!" which is posted in DIY Electrical Advice on Electricians Forums.
