maximum allowable height for scaffold tower? | on ElectriciansForums
Discuss maximum allowable height for scaffold tower? in the UK Electrical Forum area at ElectriciansForums.net
E
elsparko
really trying to get the customer to see sense, they have supplied scaffold tower for lighting replacement about 5metres off the ground, which i have been pottering away at with this shitty scaffold tower getting stuck in the sand below and hitting against the beams of the shed itself
almost tipped it several times today, got some 1.5 swa i need to throw into the very top of the shed, really dont want to do this from the scaffold tower as it will take all day to run 1 length of cable!
ive tried explaining that i would already be finished by now with the use of a scissor lift but they do not seem to see the efficiency
any health and safety i can throw at them to avoid doing this job in such a backwards way?
scaffold towers should be banned. anyone can erect them, qualified or not.bloody dangerous. with a scissor lift or cherry picker, you know that you're safe ( within the grounds of common sense|).
Work at Height Regulations 2005 - Legislation - Safety Matters (Health & Safety Community) - https://www.aisolutions.co.uk/Community/Knowledge/Topic/711/900/Work-at-Height-Regulations-2005
Any use to you?
If it does not have a tower tag on it, it is illegal. You have to have the instructions with you at all times again illegal if you do not. Must be on firm ground so you could not tower tag it as safe. If some horrid person did an anonymous;) call to HSE advising them of unsafe working practices should put paid to the tower. Might lose the job though.
Reply to maximum allowable height for scaffold tower? in the UK Electrical Forum area at ElectriciansForums.net
