Maximum Cable Length?? | Page 2 | on ElectriciansForums
Discuss Maximum Cable Length?? in the Australia area at ElectriciansForums.net
V
videz6
can someone please help me with this question
There is a 40A BS88 fuse, protecting a 10mm cable with a 4mm Earth, it is wired to Reference method C, supply is TNS and it is protected by a 30mA RCD. What is the maximum length the cable can be?
(thats all the info i have! I haven't been to collage for couple of years now and cant remember how to do it )
VOLTAGE DROP
The maximum permitted volt drop measured from the incoming supply is 3% for lighting circuits and 5% for all other circuits. p358
230v x 3% = 6.9v
230v x 5% = 11.5v
Thought I was going mad for a minute and somebody had removed my post.
This question was also posted HERE which is where I replied to it.
Ring circuit
4 x (Max Zs - Ze) Ă· ((R"1 + R"2) x Cr)
Radial
R"1 + R"2 = Resistance per meter of Line & Cpc conductors
Cr = Correction factor for conductor operating temp of 70°C
So lets assume your Ze is 0.8 (max for TN-S). The max Zs for a 40A BS88 fuse is 1.35Ω and the R"1 + R"2 of 10/4.0mm² cable is 6.44mΩ per meter.
The calculation would be:
(1.35 - 0.8) Ă· ((6.44/1000) * 1.2) = 71m
However most maximum circuit lengths are limited by Voltage Drop and the voltage drop of 71m of 10mm² cable carrying 40A is 12.5V which exceeds the 11.5V (5%) maximum VD for a power circuit.
VD = mV/A/m x Length x Current
VD = (4.4/1000) x 71 x 40 = 12.5V
So you would need to work out the max length for Voltage Drop
Ring
4 x (Max VD x 1000) Ă· (mV/A/m x Current)
Radial
So for your circuit the calculation for VD would be
(11.5 x 1000) Ă· (4.4 x 40) = 65m
Reply to Maximum Cable Length?? in the Australia area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
Well another week passed and I still don't have a proper answer to where the process is wrong. To reiterate, this is not a question for a real...
