Maximum Ze Values | Page 2 | on ElectriciansForums
Discuss Maximum Ze Values in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
but not to worry....once you get to within 200 ohms (or 100 ohms if NIC)...then pack your tools...jobs a good un.....
E54's not going to be inviting you to lunch!
you can't miss him. he's the guy with the 100 ohm earth rod stuck up his jacksie.
Reply to Maximum Ze Values in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
What readings were you expecting for the cable prior to testing? What is the make of the protective device? Is there any previous paperwork [test...
It depends very much on what RCD you are using, or even If you are using one. For example, if the RCD is 500mA then a max Ra of 100ohms is classed...
