Then add to that the figures obtained in Zs test are maybe +- 6 digits, and the fractional ohms difference is far more skewed potentially by that digit difference then you are arguing about how many angels fit on a pin head. In the real world when there is a fault of negligible impedance the fault current would likely be far above the figures talked about here. So usually a more pragmatic view is taken on the ground, so to speak, and the figures are accepted on that basis give or take a gnats b_____ks. In short panning back from the theory, at this level at least, the figures are close enough. Again in practice, the calculated Zs, say TN-C-S 0.35 assumed, + resistance tables =.55 (say) assumes 0.90, when measure you get 0.66, and a six digit difference means it could be 1.2 ohm down to errm well you work it out.
newfutile
Supporter
hemel hempstead
United Kingdom
Electrical Engineer (Qualified)
Maximum ZS values GN3
newfutile,
Vortigern,
