MCB/RCBO screwdriver | on ElectriciansForums
Discuss MCB/RCBO screwdriver in the Electrical Tools and Products area at ElectriciansForums.net
IAmSparkytus!
Newcastle Upon Tyne
Hi all,
I once had a CK screwdriver which was specifically designed for the terminals of an MCB and RCBO. I think it may have been called a power-drive but can't seem to see anything online.
Does anyone know the type I'm talking about and have any idea where I can get one online?
Thanks.
bahco do them also. most wholesalers stock one or the other. even niceic will sell you one.
One way to do it:
and
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
a bit off topic, but today i was on a job and found the N tail in hagar main switch loose. fairly recent dual RCD board. neither pozi., +/-. even impact driver would get the bloody cage to grip the cable. before even biting on the cable it was locked solid. luckily had a replacement on van. ( different make but lined up perfect. sourcing a hagar would leave customer without leccy till monday, so sod 18th. ?.).
Does everyone have one of these for terminating fuse boards or do you all prefer the electric torque drivers?
I was lucky enough to win one of these a while back which comes with the slotted/PZ driver...
[ElectriciansForums.net] MCB/RCBO screwdriver
Prefer it to my torque driver now, using the perfectly calibrated torque driver between my ears...
Don’t do enough new builds on price these days to justify £150 on a fancy electric screwdriver
Reply to MCB/RCBO screwdriver in the Electrical Tools and Products area at ElectriciansForums.net
You can buy the wera ends in singles for replacing broken and worn ends which is nice
Definitely find the mechanical clutch is better on the new one.
