I've got the Facom terminal screwdrivers, both Pozi/slotted and Philips/slotted but I don't use them that often. I don't find much advantage in terms of cam-out or maximum torque, compared to any other well made tip that fits the terminal screw correctly.
A couple of brands call them Borneo drivers which I assume is a play on the french for terminal. I get a sense of them being a solution for a non-existent problem. OTOH the traditional Steadfast terminal driver is a universal solution that fits almost every screw on the planet.
I don't know....
You wait 12 years for a thread on +/- screwdrivers...
Then you get 2 at once!
This one started in 2009, just got answered!!!
Decided against an electric torque screwdriver and have went for a new set of Klein drivers and ill look at buying the Klein SL/PZ2 driver to match.
Risky though when I've never held a Klein screwdriver before, might find i dont like them!
Anybody use them? I think they look like a decent driver.
Wiha
I splurged on a Klein slotted for socket screws and it's a nice piece of kit... Seems to take abuse quite well too...
If it’s these they are decent
i also like the American version but are blooming pricey
One major downside of PZ/S, or whatever people like to call it, it the fact that it needs to be oriented correctly. Of all the commonly used methods of driving screws, I think it's unique in this regard.
A flat head screwdriver also needs to be lined up
It does, but there's no possibility of using it in the wrong orientation.
The point I'm making is that PZ/S will line up in 2 orientations - one which grips correctly and one which might cam out under reasonable torque.
I’ve seen some sparks use a PZ/S2 on pozi screws
There's also that.
A lot of people never got the idea of using PZ with PZ and PH with PH. Chances are they aren't going to make this distinction either.
I like PZ/S, but don't believe it was the best solution for nipping up screws to fairly high torque.
