View the thread, titled "MCB RCD Problem" which is posted in UK Electrical Forum on Electricians Forums.
F
Flying Sparks
I could do with some help / guidance.
Last week I fitted a new CU into an old cottage. The house was rewired approx 30 years ago.
The Ring Final Circuits r2(2.01) was much higher than rn(0.38) & r1(0.43). 6mm & cpc 2.5mm
When I did the Continuity test I found the R1 + R2 was 2.27.
The Insulation Resistance was lower on this system ( 255 M ohm) - other systems normal.
When I plug anything into the the Ring Main it trips both the RCDs and the MCB for the Ring Main only.
Any suggestions?
Reply to the thread, titled "MCB RCD Problem" which is posted in UK Electrical Forum on Electricians Forums.
