MCB Selection | on ElectriciansForums
Discuss MCB Selection in the UK Electrical Forum area at ElectriciansForums.net
J
johndevin
Having a discussion at work ..
We are installing a 9.8 KW Shower.
If my calculations are correct this will draw just above 40A
The distribution board we are using does not fit a 45A breaker.
I think it would be safer to use a 40A than jump to a 50A.
I highly doubt the current would ever reach anywhere near 40A.
Whats your thoughts ?
P.S I know i could change the board but trying to avoid this ....
Hi John Devin - Welcome to the Forum :)
May I ask why you think a fixed load like a shower will not pull the calculated value you arrived at?
If your load calculates above the rating of the mcb then no its not safer to create a small overload for a long duration as the reg's stipulate must be avoided. So 50amp it will be.
Are you worrying about the size of the cable here then and having to upgrade it?
PS Don't you mean 'Doesn't fit a 45amp mcb'
i meant does not fit a 45 A breaker **
Because it will never be on maximum temp or else they might scold themselves.
I was thinking try a 40A first if it blows use an alternative method.
no, because it's a fixed load and yo don't need to provide overload protection, just short-circuit fault protection. 432.3 and 433.3.1 (ii). (green BS7671)
You should be using and following regulations to design and wire your circuits its this that ensures the safety of the users and of the installation, I would read and listen to the advice given, TBH it's truely is disturbing reading this comment from a practising Electrician, you have to design the circuit for the manufactered stated ratings, I would also do some research on how showers actually work, most reduce flow rates to increase temperature and don't regulate the voltage to the elements so at full power it will draw the 9.8Kw and you increase the flow rate to reduce the water temp', those with 2 power setting may have 2 elements and one ised in low power.
I would also revise you time/current tripping curves and you will find that the small overload in this scenario would never trip the mcb putting you in contravention of the regulations regarding ensuring by design you do not create a small overload of the OCPD for any length of time.
I know you are correct and wouldn't question it, I have just read those regs you have stated and can you just clarify, if its overload protection are we saying hypothetically protection of the cable / circuit from being overloaded so putting an induction hob on a 1mm light circuit for example.
And short circuit fault protection, as I read it, I may be wrong but would like you to explain, are you saying you could put a 63A or even greater so long as it falls under that reg up to PFC etc, but put an MCB on a 6mm circuit with a shower on the end that only draws 40A as its a fixed load falling with that reg as it will not exceed the specified load, so you do not need to provide protection for the cable but protection for fault only as in L-N short for example.
Is that correct?
Reply to MCB Selection in the UK Electrical Forum area at ElectriciansForums.net
Well another week passed and I still don't have a proper answer to where the process is wrong. To reiterate, this is not a question for a real...
