MCB Submain and RCBO Protected circuits | Page 3 | on ElectriciansForums
Discuss MCB Submain and RCBO Protected circuits in the UK Electrical Forum area at ElectriciansForums.net
Channel Islands
Hey guys!
I have recently been ask to install a submain to a customers workshop.
The installation I was going to use was a 100mA DP Timedelay RCD with a 32A MCB at the supply origin for the SWA submain. In the workshop I was wondering if I can install and DP Isolator with RCBOs to protect the circuits?
Obviously the RCBO's I would use will be 20A and under to allow for discrimination.
Thanks for taking time to read my post!
Do you think that maybe the method shown in the article is recommended if a time delay trip is not installed on the submain, to avoid nuscience tripping?
Don't worry about linking the outbuildings EMT to the MET it's all part of single sourced TT installation, and should be linked
Generally speaking, a time delayed 100/300mA RCD located at the supply end of the installation will effectively avoid nuisance tripping of any 30mA RCD's located at the load end of the sub-main. This will be in addition to providing added earth fault protection to your TT system...
Reply to MCB Submain and RCBO Protected circuits in the UK Electrical Forum area at ElectriciansForums.net
Many thanks all. Very helpful to be able to bounce these things around. Was fairly happy with it all initially, but once the seed of doubt is...
Nope, totally fubar.
