MCB tripping help | Page 2 | on ElectriciansForums
Discuss MCB tripping help in the UK Electrical Forum area at ElectriciansForums.net
Leeds
Afternoon. I have a problem on a lighting circuit where the MCB is tripping randomly. It is when just 1 of the lights on the circuit is turned on, I have changed the MCB, the switch and the light fitting, I have also done an IR test which was clear. It will trip at times of anything between 30 secs and 30 mins. Can anyone point me in the right direction?
Every time you find the fault you say if I'd carried out the tests taught at college it would of found this
Most of the time,yes,but there are occasions where the standard series of tests fails to produce an answer,and a bit of experience/luck/intuition provides a result. It is usually the hours spent finally finding the weird problems,that aids you another day,when things get dry...CSI electric...
Fault finding is a art, could be solved in half a hour could take several hours. You need too be through and keep notes of all readings as you go to help spot any discrepancies. No right or wrong way, just work logically when you strip the circuit down.
cant believe you got a thanks for this little slice if chud Dillan...
its not an `art`...
art is fantasy...faultfind is factual...
Lighting circuits can be fun to fault find at the best of times, especially of they trip intermittently! I'd suggest getting the client to look for ANY pattern with the tripping. Last one I had was caused by a screw damaging the cable on a switch drop exacerbated by a leak from the bathroom above!
I bet you're very good at fault finding, what with all the practice you get on here, reading through every single post and finding fault with it. You're even that good, you can pick apart sentences and find fault with that, completely ignoring the context it was written in. I think more people would benefit if you just went away.
well ....thats a good start isn`t it..
IR before continuity....
look, just go away will you..
you mean like you?
who only tests half a circuit on IR....lol..
Reply to MCB tripping help in the UK Electrical Forum area at ElectriciansForums.net
A kettle boiling fish - thats your fault right there... or is it a red herring? :)
Which rcd is it? Is it one for everything, one for a few circuits?
