MCB tripping intermittently | Page 2 | on ElectriciansForums
Discuss MCB tripping intermittently in the UK Electrical Forum area at ElectriciansForums.net
Glasgow
  • new build house 3 years old
  • Cold water supply comes into the house at the kitchen
When turning the mixer tap on in the kitchen it sometimes trips the water pump, it does not trip the pump from any other point in the house either mixer or single tap.
I have changed the pressure reducing valve, renewed the mixer tap and fitted a non return valve on the hot outlet under the kitchen sink and replaced the 6a MCB.
Any help advice greatly appreciated.
Buck Taylor RE # 1: Before you modify the electrical supply to the pump you should confirm first that the Grundfos pump is plumbed correctly. For starter, it must not be plumbed directly off the cold water mains - it must have a feed from a cold water storage tank located above the pump.
See Section 3 Installation of:
Grundfos https://showerpumpselector.co.uk/pdfs/installation-advice.pdf
Hi, thanks- yeah their is a cold water tank in the loft space. I have replaced the 6 amp type B With a 6amp type C MCB and it is still tripping?
I need some more information please:
a. What does it say on the pump rating plate for running current and for power?
b. What is the size and installation method of the cable feed to the motor from the CU?
The manufacturer states a 5A fused spur and thus BS1361 fuse protects the pump. I suspect - from some quick comparison calculations between a 5A BS1361 and a type C 6A mcb - that the product of the pump motor's short (less than 1s) start time and square of the high starting current(5-10 In) exceeds the no-trip Isquaredt of the 6A mcb by some margin but not the pre-arcing Isquaredt for the 5A BS1361 fuse (which is 44A2s). And that the fuse provides some current limiting which helps matters.
What I would do is a quick experiment: at the CU see what happens if you swap the 6a mcb for a 5A HRC or a BS1361 fuse and whether then the pump starts without problems.
Hi - why is it on a 6A MCB ? Commonly they would be on circuit with at least 16A MCB, via a 5A fuse as per @marconi.
Then if it blows the manufacturer specified 5A fuse we are headed in a certain direction ...
Hi, no it's fed directly and has worked ok for last 2.5 years!
To be clear now, you're saying the cold water feed to the pump IS direct off the mains supply?
If so, and next door is the same with the same fault, that's got to be the source of the problem.
Maybe there has been a change in the mains water supply pressure over the last six months.
All pure speculation of course!
PS, have you tried asking our watery friends on their forum?
Gas Engineer & Plumbing Advice Forum - https://www.ukplumbersforums.co.uk/
Reply to MCB tripping intermittently in the UK Electrical Forum area at ElectriciansForums.net
E
Mixer Tap Cartridge change advise. Hi Our kitchen mixer tap is leaking around the bottom. Unsure where the leak is coming from but suspect/hope a...
Eejay
E
Low pressure mixer spray tap recommendations ? I'll be installing a new kitchen, DIY, and the Mrs wants a mixer tap with a switchable...
Splitty
