MCB tripping | on ElectriciansForums
Discuss MCB tripping in the UK Electrical Forum area at ElectriciansForums.net
called out as a light had come loose from its ceiling bracket. customer reported that since the light had loosened, when ever they switched on a light switch the mcb tripped. No problems or trips before.
upon visual inspection it showed that a neutral ( one of two had come loose and was now in contact with earthed metal casing) all other connections secure and as expected.
no damage to cabling
reconnected loose neutral and circuit worked as normal.
As this was a MCB and not RCD or RCBO I'm baffled as to why the mcb tripped at all. can any one shed any light on this.
No live conductor was secure, in its correct terminal. Earthing conductor secure, the only cable that was in contact with the casing was one of the two neutrals.
regards live conductors ( looped at switches, i assume as only one switch wire at the light fitting no loop)
Did you carry out any tests? R1+R2, insulation tests and an rcd test would have been my first thought after that scenario.
no unfortunately it was a very quick call and i was time limited, the fault appeared obvious at the time it was only later that i thought hang on a n-e fault shouldn't trip the breaker.
arcing sounds like a good possibility one i hadn't thought of.
Are you sure the neutral black wire wasn't the switched live??
yes i am, if it was the switch wire as you state when it was reconnected it would of just tripped as soon as the switch was turned on.The switch wire (red single) had not moved from its terminal in the light fitting. As stated neutral loop and earth loop at light fitting, lives looped at switch. Circuit wired in singles not t+E.
To add Mcb was tripping when any switch further down the radial than the light in question was switched on.
Ah there you go then not enough info
Reply to MCB tripping in the UK Electrical Forum area at ElectriciansForums.net
Yup will do exactly that when I'm back down there. Thanks for the help
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
