MCB tripping | Page 2 | on ElectriciansForums
Discuss MCB tripping in the UK Electrical Forum area at ElectriciansForums.net
called out as a light had come loose from its ceiling bracket. customer reported that since the light had loosened, when ever they switched on a light switch the mcb tripped. No problems or trips before.
upon visual inspection it showed that a neutral ( one of two had come loose and was now in contact with earthed metal casing) all other connections secure and as expected.
no damage to cabling
reconnected loose neutral and circuit worked as normal.
As this was a MCB and not RCD or RCBO I'm baffled as to why the mcb tripped at all. can any one shed any light on this.
If it was the neutral from the fitting itself that had come loose and touched the casing then wouldn't it become live due to losing its neutral connection?
No it doesn't become live par' se, it potential can rise up to mains voltage with reference to N or E, it would just complete a circuit if it touched down to earth thus lighting the fitting, unless rcd was covering the circuit that is, if the load was inductive in nature that was broken then inrush spiking as the loose N arced would easily take out the mcb.
What about the possibility of reversed incoming polarity?
Could even have been reversed polarity somewhere within the circuit at some point , if the op had seen the situation he described he should have tested at that point and then at the origin and correcting the fault before re energising that circuit
Reply to MCB tripping in the UK Electrical Forum area at ElectriciansForums.net
Yup will do exactly that when I'm back down there. Thanks for the help
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
