Mcb tripping...? | Page 2 | on ElectriciansForums
Discuss Mcb tripping...? in the UK Electrical Forum area at ElectriciansForums.net
Hi,
ive read a lot of posts on here regarding mcb tripping and still need advise please. I have a kitchen ring tripping the mcb. I realise that 9 out of 10 times its an overload problem however I've unplugged all appliances and the mcb doesn't even stay on. From the other posts it seems like another cause could be a L-N fault shorting it out. I've done an Ir and although not perfect results show >100Mohms. I've also removed all cover plates and tested each cable in turn and insulation test seems fine from each cable.
I've done a full set of tests on the circuit with continuity, insulation & Zs @ each socket and all test fine.?!
any advise you can provide will be very helpful and thanks in advance..
all seems fine for awhile and then mcb trips every 10 mins until it gets to the stage of not even staying on when everything is plugged out? To me it seems like an overload problem to start with and then turns into L-N fault but I very well could be wrong. Any help welcomed..
owners say say it happens randomly and not when a certain appliance is plugged in.?
ive ordered another mcb but is it likely to be that? Thanks
If you only very lightly touch the MCB and it trips its a knackered MCB so you've done the correct thing ordering a new one.
This to me tells me that the MCB has been exposed to overload for quite some time. More investigation work is needed on the circuit. What size conductors are they, can you upgrade the MCB? Does anything need splitting?
I wouldn't just replace the MCB and hope for the best, might be okay for a year or so but long term you need to get to the root of the problem.
Mark.
Reply to Mcb tripping...? in the UK Electrical Forum area at ElectriciansForums.net
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
A kettle boiling fish - thats your fault right there... or is it a red herring? :)
