mccb lay out | Page 2 | on ElectriciansForums
Discuss mccb lay out in the Talk Electrician area at ElectriciansForums.net
its question from collage!! it says its a biofuel machine. why does it sound to high? we got a leaflet with it explianing specifications cnt remember what is on it? so basicly what you are saying is that u it will need its own supply.
i think it was 415v
50,000W
grouped with 2 other cable
30 degrees
in metal trunking
You'll need to figure that out with the regulations for your locale. You start wth a cable that will handle the max load then start penalising for length of cable, how it's run etc etc. I don't have a copy of the UK regs I'm afraid....assuming ur in the UK.
Reply to mccb lay out in the Talk Electrician area at ElectriciansForums.net
OK for a simple load. What happens with (say) SMPS LED drivers ? I'd guess : Loads aren't perfectly balanced, especially during startup, so one...
Nothing wrong with it. Which manufacturers have you got this information from? What do you mean by trip speed? Fuses and MCBs can operate in the...
davesparks
