MCCB used as a final circuit supply | on ElectriciansForums
Discuss MCCB used as a final circuit supply in the UK Electrical Forum area at ElectriciansForums.net
london
Currently pricing a 250a Power upgrade for a small warehouse, the new 6 way 250a MCCB panel will essentially be used to supply x2 fuseboards however i want to have the MCCB panel also supply the larger plant as i want the MCCB panel to take the heavy loads as the client said he will never be installing any more fuseboards he would rather have the MCCB panel handle the below heavy loads.
63a 3 phase compressor
100a spray unit
now for example i am going to be using the Hager HDA063U 63a tripple pole MCCBs however the problem with this is that the spec of the fixed equipment is a 63a type D Breaker, These hager MCCBs dont have a time delay setting on them only Ir x In.
am i being daft and should i just not use the MCCB panel for type D loads
Reply to MCCB used as a final circuit supply in the UK Electrical Forum area at ElectriciansForums.net
Useful to know. In my case there will be 150x150mm trunking at top/bottom and almost certainly I will be using tri-rated cable, probably 70mm...
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
