Measured and calculated Zs | Page 2 | on ElectriciansForums
Discuss Measured and calculated Zs in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Assuming you took your R1+R2 readings between Sw. Live and Cpc terminals, don't forget to check connections in your switches aswell.
Max R1+R2 for a 1.5mm² lighting circuit should be under 2.71Ω so that you satisfy the 90m max circuit length for Voltage Drop.
Reply to Measured and calculated Zs in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I have a question i hope someone can just give me a little clarification on . When carrying out preliminary cable design for a given circuit we...
