richardg
Evening all,
i just would like some clarification on the best practice concerning mechanical protection of garden lighting flex. I have installed swa throughout the system buried 500mm terminating in ip56 box's to be buried underground. The system is connected to a garage ccu with RCD protection.From the box i am connecting a saxby mains 7w led lamp which has a inter-grated flex. As the flex will be buried do i have to provide mechanical protection ie pvc conduit?
When using ip56 box's do you still normally magic gel to keep moisture out?
Thanx Richardg
Thanx Richardg
