Megga | on ElectriciansForums
  • Thread starter Cj24
  • Start date
  • Replies 7
  • Views 2K
Discuss Megga in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
C
Cj24
How do you mega a cicuit and wat should tester be set on etc cheers for the help
Yes I know there are megga testers but iv heard people say they are going to megga the armoured or the circuit
As previously stated Megger is a brand name it is a Insulation Resistance test you carry out even though people say they megger a circuit, if you put down in a exam you megger a circuit it will be marked wrong as you have used incorrect terminology.
It is better to start to calling it a IR test now.
Its just a saying using the meggers name i wouldnt like to test at megga volts 500 is well enough
it should be IR or Insulation resitance test , infact to confuse matter even more people are putting do not Meggar on ther equipment , so if i use my Fluke on 1000 volts it will be ok then lol
Cj24 you have started a thread on every test known to man.....unless you have some knowledge of the basics I cant see that an internet forum can be of any real help to you.
Reply to Megga in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi, Do you have the user guide. If not I will put the link at the end of the mail. May be worth checking that the meter has been set for UK usage...
