Megger 1552/3 Problem! | on ElectriciansForums
Discuss Megger 1552/3 Problem! in the Electrical Course Trainees Only area at ElectriciansForums.net
Simonslimline
South West, Bath
Is there an option to turn off the audible sound when a test is carried out or if the tester is applied to a live circuit on the wrong setting?
I just received a megger 1553 and can't get any audible sound to work.
Thanks in advance. :smile:
I think there is a Megger rep on this forum, might be worth sending him a PM. Or to the forum sponsor Test-meter.
Just phoned up megger and had a chat, the buzzer is broken in mine unfortunately. A replacement costs around 50pence, labor charges on top of that will bring the cost up considerably.
Looks like i will have to contact the seller and explain that there is a problem. :frown:
Its a pain when that happens, a guy I do work with bought two Megger 1730's from eBay from different buyers and both had faults and had to be returned
To be honest i wouldn't of gone for it if the defect was explained in the listing. Was a good deal at ÂŁ255 with fused fluke test leads and a socket and see adaptor.
I want a tester without any defects though. The continuity buzzer would get used as well.
Sure if a hunt around again i could get a decent deal.
Reply to Megger 1552/3 Problem! in the Electrical Course Trainees Only area at ElectriciansForums.net
It does seem to me that there's a capacitively coupled voltage to each set of downlights (on the light side of the switch), and when you put the...
Also posted in DIY. strange one in my kitchen. 3 sets of 2-way switched mains GU10 Philips down lighters. ( no dimmers) Have been fine for...
