Megger 1552 Best Price | on ElectriciansForums
Discuss Megger 1552 Best Price in the What's the best price you can find for this? area at ElectriciansForums.net
stu-rob
Whats the best price anyone has paid and where from for a megger 1552?? Looking at buying one in next couple of weeks and dont want to be ripped off, CEF quoted ÂŁ515 + VAT, and seen here http://isswww.co.uk/products/Megger/MFT1552.aspx for ÂŁ469 + VAT.
Anyone used that site to buy anything before?? Are they reputable??
Your help would be appreciated.
I'm pretty sure the 155 range replaced the 150 range. And there are 3 different models:-
1551- Performs all 17th edition required tests (Low Ohm Resistance/Continuity, Insulation Resistance, No Trip Earth Fault Loop, PFC and RCD tests)
1552- Same as 1551 but with Auto RCD tests.
1553- Same as 1552 but with Bluetooth connectivity.
I think... lol
I have been offered a 1502 at a good price (with calibration certificat ), can anyone tell me if this tester is up to the 17Th edition. as i will be having a nic assessment soon.
many thanks
The new "17th edition kits" are a marketing ploy. If it can do an Rcd,continuity,Insulation,pfc,Eli test you can use ti for testing provided its calibrated. The only major change in the 17th regards readings is the Insulation Resistance values.
Reply to Megger 1552 Best Price in the What's the best price you can find for this? area at ElectriciansForums.net
