megger 1552 faulty | on ElectriciansForums
Discuss megger 1552 faulty in the UK Electrical Forum area at ElectriciansForums.net
C
clydey
dropped my megger - about 2 ft -it worked ok after for 2 tests.
noticed all the leds lit on top screen and would not switch off except by removing batteries.
all internal fuses checked ok and all connections ok and no damage to pcbs.
i am presuming this fault is not actually a fault but a vibration detector sensing the fall and putting the megger into check mode.
Q.noticed several pins on the inside on one of the pcb's including the reset pin does any one know the specific reset sequence.
i imagine it woud go like short reset pin to pin x and connect battery remove short - check mode cleared
cheers
Always liked the 1552's. Physically they were very robust but electronically I feel they had a lot of issues! I had 3 or 4 in my time which constantly blew the external 500mA fuse and sometimes the internal one. Now using the 1720 which has changed the game for me, great unit! :)
Reply to megger 1552 faulty in the UK Electrical Forum area at ElectriciansForums.net
SOLVED Thanks for all the help. It was nothing to do with the smoke detector. In this new hole (where there will be a light fitting) three white...
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
