Megger 1552 strange readings!! | Page 2 | on ElectriciansForums
Discuss Megger 1552 strange readings!! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Ill check the batts there at 10.5v ill change them to rule that out, if not ill have to ring megger, i was checking to see if there was something glaringly obvious that i was missing - thanks tony!
Reply to Megger 1552 strange readings!! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Having some issues with my companys fluke 1662/1663 tester. Zeroing 2 leads for continuity test we get the value 0.08 which is expected. The issue...
Induced voltage can be a bit of a red herring when using DVM my guess is somethings moist.
TerryBNZ
T
