Megger 1700 tester opening | on ElectriciansForums
Discuss Megger 1700 tester opening in the Electrical Tools and Products area at ElectriciansForums.net
B
blackops
Hi i have a Megger 1730 and need to open it up to replace an internal fuse.
Does anyone know how to open the 1700 series testers?
it's tedious but not difficult. i assume they will be similar to the 1500 series as regards opening. if so.......
first, after removing the battery pack, carefully (using a stanley blade) ease up a corner of the front label, then peel off label. under the label you'll find 4 fixing screws. remove these and ease off the front panel.unplug the ribbon cable and take front panel out of the way. don't lose the gasket. then the main halves of the casing ( again 4 screws) can be parted. the sockets panel for your test leads willl be a bit "sticky". when refixing the label, if it does not stick well,use a smear of pritt stck. don't use any form of permanent adhesive in case a future strip down is needed.
Nice answer Tel, that was like watching Blue Peter again - shame you didn't need scissors and a responsible adult!
There's a lid on the back marked battery cover, with two screws. Unscrew the screws, remove the lid, et voila two fuses revealed. Have you actually got a 1730 :confused:
Reply to Megger 1700 tester opening in the Electrical Tools and Products area at ElectriciansForums.net
There is a lock on it, press the test button down and press the lock button, the symbol will appear on the screen in the middle right hand side...
KT66EVA (KT66DL & KEWEVA) - ÂŁ1073.60 + VAT if you shop about as a combo
