Megger fault | Page 2 | on ElectriciansForums
Discuss Megger fault in the UK Electrical Forum area at ElectriciansForums.net
buzzlightyear
Nearly Esteemed
star command
Has from me last post, I wonder if any body know or has a problem with a megger error conecet fault before I send to a repair jobby.
When I had separates, the Megger LTW325 I had was rather hit and miss on the low current tests. I sometimes used to use the trick mentioned in the Kitcher book - lock off breaker / RCBO, join L and CPC at circuit end, and use a high current test between bus bar and outgoing live at CU. It had the extra benefit of thoroughly confusing anyone watching too!
and elimunates any false readings caused by RCD. must remember to remove the short brfore energising though.
Reply to Megger fault in the UK Electrical Forum area at ElectriciansForums.net
Yes that was me. If you change your mind give me a shout and I’ll sort something out for you 👍
Having some issues with my companys fluke 1662/1663 tester. Zeroing 2 leads for continuity test we get the value 0.08 which is expected. The issue...
