Megger good price? | Page 2 | on ElectriciansForums
Discuss Megger good price? in the Talk Electrician area at ElectriciansForums.net
logs are for putting on the fire. 1552 or 1553 all the way. with a 1553, the bluetooth is a pain anyway, so just don't use it. either of the above can be got 2nd hand for around £300, calibrated if you're lucky.
Other than the lack of the auto RCD test function. Is there anything else that this tester is lacking?
other than roads, sanitation, education, what have the romans ever done for us?
The 1700 series came out in about 2010 to replace the 1550 series
the first 18 months of service had lots of issues until the firmware was V 1.09 or greater this solved most issues
Firmware V2.08 is the latest
The 1st year calibration of a 1700 series is best done by Megger so the firmware can be updated and any issues sorted under warranty
Megger calibration is about £65.00
yes
Key Features
  • 2-wire no-trip
  • PFC measurement at same time as loop resistance
  • High current loop testing
  • Auto-start tests on continuity and loop resistance – no need to push the button
  • Displays test voltage at the same time as insulation resistance
  • Dual test buttons for left or right-handed operation
  • Polarity test
  • RCD ramp test to measure RCD trip current with fast ramp option
  • Adjustable insulation alarms
  • Phase to phase loop test
  • RCD auto test & programmable tripping current level
  • 3 phase RCD test
  • Phase rotation test
  • Remote switch probe included
  • Weatherproof to IP54
What's Included:-
Megger MFT 1720, 3 Wire Test Lead Set, SP5 Switched probe, Mains plug Test Lead, Neck Strap, Quick Start Guide, Hard Carry Case, 8 x AA batteries, Calibration Certificate and User Guide
Insulation limit alarm – Buzzer sounds if result is higher than limit set
0.5, 1,2, 3, 4, 5,7, 10, 50, 100, 500 MΩ
Condition as new
Reply to Megger good price? in the Talk Electrician area at ElectriciansForums.net
