Megger LRCD 210 Fault | on ElectriciansForums
Discuss Megger LRCD 210 Fault in the Electrical Tools and Products area at ElectriciansForums.net
I
ICE
Hiya Lads,
I have a LRCD 210 that has developed a fault, it says CHF on the main screen, any idea's?
:cool:ICE:cool:
Cheers Mate.
I have tried searching Megger TSG but no found. any suggestions?
Hi ICE
CHF on a LRCD 210 indicates a checksum error
First try replacing the batteries, if the error persists then the unit has a fault and will require servicing.
If theunit is under warranty then the usual procedure is to return to the place of purchase or alternatively you may return the unit to our factory for repair. An RA number must be obtained from our service department (01304 502243) before sending the product.
Kind Regards
Megger TSG
Reply to Megger LRCD 210 Fault in the Electrical Tools and Products area at ElectriciansForums.net
I see fluke has a new mft out soon, looks like they are copying dig screen, 1672 plus, cheaper then megger. Has any body put a order in for one.
Exactly. I was going to ask on the earthing once he clears this boiler fault (suspect on internal component). OP mentions oil boiler but makes no...
