Memera 2000 RCBO definitive answer | Page 2 | on ElectriciansForums
Discuss Memera 2000 RCBO definitive answer in the UK Electrical Forum area at ElectriciansForums.net
lurch
Hi
I have seen a couple of posts on this subject but they go back a bit and dont appear to have a definitive answer. I have a MEM Memera 2000 CU, where I need to provide RCBO protection to the lighting circuit to cover some additions I have made in the bathroom. There is already a Eaton 16A N14928 RCBO in place for a recent upgrade in the property. I am struggling to find this component, so would apreciate some help in establishing where I can get the correct RCBO that will fit (I also notice the coper busbar is a little wider than usual, but if the worsts comes to the worse I can file a little off)
Thx in advance
I used to fit loads f those boards , If I were you just make sure the existing MCB has the facility to attach the new pod , because some MCBs didn't have the removable section at the front i.e. solid type front , if it has the facility to accept then yes all you need is the RCD pod ..........
I could be wrong but I am sure MEM aligned both types so they are compatible a fair few years back.
Chaps thanks for the replies, the customer has gone for a local RCD. Tried to sell the rcbo, but all he wants is his led vanity unit working at the most cheapest cost. Incidentally, a week ago, at the property I disconnected a no longer required shaver socket 4' feet away from the new vanity unit. Said to the customer, had he remembered, the cable to the old socket, which could of been 'damaged', been replaced and 'moved' to the new position! Not now though.
Reply to Memera 2000 RCBO definitive answer in the UK Electrical Forum area at ElectriciansForums.net
