Menvier & Channel | on ElectriciansForums
Discuss Menvier & Channel in the UK Electrical Forum area at ElectriciansForums.net
Ross1
Hi guys,
can anyone of you tell me if menvier or channel fire accessories will be compatible with a (zircon) bardic Honeywell fire alarm system?
many thanks
Ok I need 2 x sounder beacons, 2 x break glass call points, 1 x heat detector, 1 x standard detector. I also need to move 1 x existing break glass call point and 1 x sounders beacon 3 foot to the right.
Is is there special joint kits for FP cable?
By the way, this all has to be installed by end off play on Thursday.
Regards
As above, with KAC 470ohm call points, Fulleon roshni/flashni`s......cable needs to keep integrity, so suggest any joints, are crimped in a 20mm gav through box, using 20mm fire rated stuffing glands. Plenty of good suppliers will have items delivered next day...
Hope this helps
Reply to Menvier & Channel in the UK Electrical Forum area at ElectriciansForums.net
Hi Guys Got a job where property is set up with Honeywell evohome TRVs and controlled via central panel. They're having an extension done with...
Hi All, I am looking to start installing commercial fire alarms, I want to be able to design, install and commission. I am a member of NICEIC so...
